Jig for aligning Mounting plate
dnale
South Lyon, Michigan
Has anyone made a jig/template to hold the ends of this shaft so you can have the opposite ends alligned and tightened before putting them in the sled?
I can't pull up the image of the shaft but it's the one that has the plate one each end and has 3 bolts through the tunnel and one bolt into the shaft per side....darn cookie blockers...
