Another water skipping question
SNOWRULES
Ottawa. Ontario, Canada
i can't for the life of me figure out where the water is getting into my clutches. i sealed the hell out of my belly pan and have all my vents taped up. i think it's getting in through my footwell so my next step is to make some sort of aluminum plate to rivet behind the footwell then seal around that. has anyone else ver done this? does it work? thanks
did you roll the sled over and seal the front of the tunnel ?
way up front by the heat exchanger in the corners? in front of axle
track seems to carry it around and throw it up there
hey snakebite thanks for the advice i siliconed those corners this weekend and all around the front heat exchanger and now i have no more belt slip no water getting in at all thanks again man worked like a charm
