jacksonmt
- Feb 18, 2006
I have a 2002 Viper and I'm having two problems. The temperature light keeps going on and off while riding. The light comes on sometimes even when when you first start it and stays on 10-15 miles.
I also have a problem occationally when I hit the brake at a high rate of speed. The sled will start to bog out but if I hit the choke it will fire right back up and run great. I can go quite a while before it happens again.
I have cleaned the carbs and that doesn't appear to be the problem. Any suggestions?
Woodydog
For the light going on or off, you do know it is a low gas light also, right? For the bogging problem, how is your belt and have you ever cleaned your power valves?
TimeBomb
Woodydog said:For the light going on or off, you do know it is a low gas light also, right? For the bogging problem, how is your belt and have you ever cleaned your power valves?
no, the low fuel light icon is different than the coolant temp light icon. i think you are thinking of the warning icon.
check your connection to your temp sensor on your head manifold, could be loose.
