SRX7
Can some fill me in on a step by step process on checking compression.
Thanks.
Thanks.
SRX7 said:Can some fill me in on a step by step process on checking compression.
Thanks.
This is how i do it,, others may do it different.
1-warm up motor to operating temp.(take for a little ride if you can)
2-pick a cyl. and pull the plug,,screw comp. tester in,, hold throttle wide open.
3-with BOTH hands,, give it a good hard 7 pulls.
4- put that plug back in and move to the next cyl. and repeat above steps.
Record each test,,leave each pulg in except the one your working on.
I usually do each cyl. twice just to make shure the reading's right
and make shure key is off....
**sj**
Life Member
daman is right on...one additon....make sure the "throw" is the same length as your spark plug..also....IMHO...Snap On is the most accurate
redsnake3
the snap on tester my buddy has always reads about 25 lbs more than any other gauge. but yeah the steps are really good, its good to have two people to do this so one can hold the throttle and the gauge and the other pull with 2 hands.
SRX7
**sj**
Life Member
you WILL get wrong readings with a snap on or any other with the wrong length throw...measure the thread length....no need for two...use a rubber band and pin her to the bar...I even take a large band to hold the gauge in sight while I pull....make sure the key is out of the machine... pull until it stops climbing...like 8-10 pulls...
also...you can check leakdown letting it sit under compression..
SRX7
Do you get higher numbers with a cold engine or hot ? Thanks
Mac
Compression
Why leave the other two plugs in each cylinder? Why would this give inaccurate readings?
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
There is absolutely no point in putting the plug back in. Take all of the plugs out, hold throttle wode open and pull, do this for each cylinder then put all of your plugs back in.
**sj**
Life Member
warming the engine expands the rings and seals..the idea is to get what compression you have WHEN IT'S RUNNING RIGHT? not while it's sitting outside....
2000 srx is correct there is no reading advantage towards plugs in...but it will keep your engine bay cleaner!
daman said:This is how i do it,, others may do it different.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
daman said:^^^^^
Wasn't going against you, just wanted you to know that you can save time.
2ooosrx said:Wasn't going against you,
np
We all do things are own way for a reason!!!!
SRX7
I did them when it was cold ( not time to run it yet but will ) all 3 were 125 lbs right across cold.sj said:warming the engine expands the rings and seals..the idea is to get what compression you have WHEN IT'S RUNNING RIGHT? not while it's sitting outside....
