kysledneck
Hey! My right hand still is weak from 2 weeks ago when I rode in Gaylord area (Carpal tunnel) What is a good lefty? I see ebay has a Woodys for $45 & then the go up from there! Just want a good one to rest my right arm some Thank you. I have a 97 SX 600 twin.
yamahagirl
Check your hyfax ...
My dad put a gold finger on his rage ... easy to install and you can switch between the right and left.
His was around 100. Power madd also does one ...
45 seems pretty cheap!
kysledneck
Seemed cheap this is it!yamahagirl said:My dad put a gold finger on his rage ... easy to install and you can switch between the right and left.
http://cgi.ebay.com/ebaymotors/Xtre...00449QQitemZ4617344061QQrdZ1QQsspagenameZWDVW
yamahagirl
There is a few threads on the 4-stroke side about left hand throttles ...
http://www.ty4stroke.com/viewtopic.php?t=23611&highlight=left+hand+throttle
http://www.ty4stroke.com/viewtopic.php?t=24383&highlight=left+hand+throttle
Don't know if these help you out at all ...
kysledneck
Thank you! Anything helps!yamahagirl said:There is a few threads on the 4-stroke side about left hand throttles ...
I have a gold finger and love it. Used it alot lst weekend in the up trail and off trail.
Snobunge makes a great one....larger handle than the gold fingure for full hand control rather than just one figure.
I made my own for about $30. It works fairly well, but does not have a lockout (in case someone else rides your sled).
I will probably buy one next time instead of making my own. Either a Goldfinger or the sno-bungie one. When I made the one I have, all I could find was Lefty's which is a high quality piece of equipment but over $200 at the time.
Dfunkdf
wow 200 for a throttle hell i put an right hand brake on cheaper than that master cylinder and all
Roger
Check "royaldistributing.com" .
Go to their winter catalogue. It is there somewhere. It's also Canadian dollars!!!!!!
That was 3 years ago . . . None of the others were out yet.
