VmaxSx600
I was wonderin im lookin at a performance pipe or silencer what should i get for a budget of about $300 and what kind and were to order it from?
What sled? if it's for the one in your name(600sx) and its a twin your only option is a set of twins. Doesn't appear that there was much interest in an aftermarket single for that sled.
You can find a few cans for the stock pipe, or some companies still make or have twins in stock, but they are asking about $500 for a set new. There have been used ones for sale on here and ebay.
monker
If you're looking for twins, I can set you up. I've got a set for sale. If you have a tripple, 300 should cover used pipes, but you'll need to make clutching changes too.
VmaxSx600
Yes my sled is a 98 V max 600sx and the bad part is that it is a single no double of triple.
monker
I think you mis-understood. When refering to twin or tripple, it is the number of cylinders. Check that out and let me know what you've got.
VmaxSx600
it has two cylinders
600 twin
I wouldnt pipe it, but I would add the thin head gasket . A few bucks will go along way and you will keep it together...
IMO
IMO
monker
I have a set of pipes and all the info that goes with them if you're interested. I never had a problem running them and it made a big difference over stock. The pipes were from Hauck and I have the clutching that will go with them.
monker
monker
