DHSRX
I have a 2001 SRX that I was taking out on some speed runs. Around my 4th or 5th run there was a major loss of braking force. I removed the pads and took a look to see if there was anything damaged or dirty. Everything look clean and still looked new. I am thinking that the brake fade was caused by excessive heat because the next day the brakes worked just fine at moderate speeds.
Has any body experienced this? and should I be concerned about it?
DHSRX
DHSRX
