<Is it common to loose coolant if?
max
I was riding on much hardpacked trails with my mm 700-01 this winter,it was not much snow here in Scandinavia.I installed new hyfax,and i was loosing some coolant through the season,not much but.is it common? thanks
Coolant leaking!
A closed cooling system shouldn't use any coolant at all. In your case you might have a loose connection or fitting on one of the coolant hoses. Check all of your hoses and look for any visbile signs of coolant leaking. Could be leaking slightly at the waterpump via worn out seal. If you have studs check your heat exchangers for damge from a flying stud. Good luck.
