slikRsrx
Anyone know a easy fix on secondary spring maybe,,twisting tighter?
This thing is all day on hard pack,,but the minute you go off trail it only revs 7200rpm like it's bogging down any suggestions?......thanks
what twist are you running on secondery now? give it more twist and less helix if yours are steep..
A shallow helix, like a 47/42 will work very good, I had that and a green spring at 80 degrees. Worked very well with a 1.5 track.
check/change the primary spring. that is exactly what my et410 was doing last season and that was the fix.
