Arctic Cat Bars on an SX??
St. Lawrence County, NY
Is anybody running Arctic Cat Handlebars on an SX/SX-r/SRX?? I was just wondering how they would work on an SX? I'd like to see some pics.
I would like to be able to use the stock warmer control, but wasn't sure if I could w/ the Cat bars. Any help would be appreciated.
Thanks. ;)!
:winterrul i ran a set of arctic cat crossfire bars on my 01 sxr!i had to do a bit of moding to get them to work. these bars give you about 4in of lift over stock, so you need a longer brake hose, also i took the parking brake cable off. the other cables & wires are fine! i had to cut the one hooked end of the AC bars to slide the throtle assembley on. then i put a handle bar hook in it's place! i used a file to shape it to match the other side. then i glued a set of AC grips on. you could use the AC hand warmers (re wire) or YAMMIES. i never use warmers so i didn't bother with them. ......these bars are awesome! i had a BOSS seat on the sled the two worked great together!
my 01 sxr.
