hereismylife
I have a 97 600 vmax xtc and a 00 700 sxr
my 00 has viper skis on the front so it drops the front about 1'' down.
right now my 97 sits about 2 1/2 inches higher than my 00
what can I do to make my 00 front hight 2 1/2 inches higher with the viper skis still on?
do they make extention brakets for the shock?
thanks joe
thanks joe
yamaholic22
You can get adjustable brackets from hauck or somewhere else may have them as well, or you could try tightening the preload on your front springs to get the desired ride height. Try that first.
hereismylife
thanks
I looked at http://www.hauckpowersportsinc.com/ but no luck
I will call them tommorrow
my spring is just about at the top of the shock not much more to adjust
kysledneck
hereismylife
thanks called them
front height
You could reverse the the top shock mounts! I read on theis site that you swap sides of the upper shock mounts and when you swap them you need to turn them upside down and do a little grinding to get them to fit. Mine is the same way but I am not sure if I should worry about the inch because the sxr has plenty of height now.
yamaholic22
rtjim said:You could reverse the the top shock mounts! I read on theis site that you swap sides of the upper shock mounts and when you swap them you need to turn them upside down and do a little grinding to get them to fit. Mine is the same way but I am not sure if I should worry about the inch because the sxr has plenty of height now.
that is for an srx, not an sxr.
BlueIronRanger
- Nov 26, 2003
SX-R's are designed with more "sit in" in the front suspension then the Vmax sleds. both have the same travel but the difference is in the shock/spring combo.
FuzzButt
Don't forget there is a difference on the XTC sleds in the shocks and rods.
obsessed
- Dec 5, 2005
This guy posted his srx on SF seeing as the chassis are similar u could look into the same upgrades just google Sno-tek. pretty sick but a little spendy.
obsessed
- Dec 5, 2005
sorry forgot to post the link to the original topic on SF you can see how the sled really looks. http://www.snowmobilefanatics.com/forum/topic.asp?TOPIC_ID=43595
j_k_auto said:I have a 97 600 vmax xtc and a 00 700 sxr
thanks joe
I did this on my 01 sxr and there really are two ways to fix it, the first is to change your sxr to viper trailing arms and spindles, the viper ski saddles are smaller than the sxr and the viper trailing arm tubes are longer, so if you switch to viper trailing arms it fixes the problem.
I decided to make custom mounts, since i have access to a mill, i milled the viper saddles and mounted the old sxr ones on top of the viper ones, it gave me back the height for free. I may sell my mounts in the spring since i am going to switch to powder pro skis for next year.
obsessed
- Dec 5, 2005
Sorry guys I forgot to post the link so you could see how the sled looks with the suspension upgrade. http://www.snowmobilefanatics.com/forum/topic.asp?TOPIC_ID=43595
