sxrron
I have a 01 VMAX 600 dlx with reverse. At wot the rpms stay at 9000 as long as I keep it at wot. The sled has 1800 miles and a new belt. What is the best way to bring the rpm's down? (8500 I believe is target) Thanks for the help.
yamaholic22
add weight to those arms. Those things overrev like CRAZY with stock setup. Throw a 3.6g in the inner holes, that's real close.
The inner comes stock with a 3.6 gram. The outer is 2.4 gram. Change the outer & inner both to a 4.5 gram rivet & your rpm,s will be close.
yamaholic22
Turk said:The inner comes stock with a 3.6 gram. The outer is 2.4 gram. Change the outer & inner both to a 4.5 gram rivet & your rpm,s will be close.
Oh damn your right i'm all bass-ackwards today. Not sure what i was thinking there, but Turks right
sxrron
Thanks for the quick responses.
