I'm lookin to put a 1.75-2.00 track under an srx
Dr Nitro
anyone ever drop and roll an srx or can this be done with smaller drivers???
Thanks guys
DOC
1.75" lug will fit with the stock 9 tooth drivers, this keeps your gearing and speedo correct. You need to pull the front heat exchanger protectors, and the tunnel wear sstrips and it goes in no problem, ran my 01 srx with this, worked great!
anything over 1.75" lug and you need 8 tooth drivers, new gears and chain and speedo drive from a mtn max.
