SRX ?
Srxspec could you get that number? I would like to see what other engine builders have to offer. Thanks ;)!
900 CC stroker
Hauck is taking the 780 kit and building a stroker crank for it which makes it a 900. My buddy just had his done and Pat says it makes 221 hp. That sounds like a lot to me but what do I know. Hav'nt seen the dyno sheets yet. Pat did'nt send them. Hmmmmmm?
Madmatt
Thanks for the replies. It is being built as a 1000. Pat's 900 should not even stand a chance at 220hp. LaLaLa
bluehammer that would be cool, but I am building a legal 1000 imp. which should be around 250-260hp and it's not cheap. But as they say, you want to play you pay...
Bender does or at least did make a pro stk 1000. I know they built a viper for a guy...but I don't know who.
We've just started to run an Iantomassi 1000 SRX and the engine is strong...we like!
doktorc what kind of power does it make? What pipes are you using and is there anything that you ran into that you could give me a heads up about?
Well...I only know what I've been told at this point...
253hp @92-9400
Jaws pipes.
Get ear plugs 'cause its effing loud!! oh and loctite b/c solid mounts shake things loose.
So far we're still ironing the bugs out of the chassis. The engine runs very well and pulls hard but we don't really have much to compare it to...other then to say its alot faster then the Viper.
I should see those kind of numbers or maybe a little more. Do the pipes have silencers ? I will be using Jaws pipes also. When I get mine up and running maybe we can trade some info on what works and what does'nt. Thanks
