simon jones
Im thinking of buying the bender triple pipes and i was wondering what else do i need to put on it to have the best performance and best reliability...and also how much would everything cost (canadian) ?
thanks
thanks
simon jones
and what about the MPI pipes
For a viper adding any brand of pipes you will need a rear heat exchanger, EGT gauge to montior A/F after install, head mod to even compression out on all cyl, and the bender optiocool head gasket. Make sure to take the time to dial it in and your all set.
mbviperboy
bender pipes with rear heat exchanger, opticool head gasket and clutch kit. Not running egts as long as you jet to bender specs should be ok. Head mod not done yet maybe next year. sled pulls hard can really feel the extra hp
simon jones
What is the price for everything canadian?
mbviperboy
bought it all used for 750cdn, had to order some clutch springs and weights from bender cost me an extra 140. look around and you might find some used ones, Good luck
I have the same mbviperguy except heat ex. because mine is mountaian viper already has is. bought mine from bender canada(jerry prossler) in ontario fro 1700 brand new. The mpi pipes are bender just modded abit for high altittude, i've hade mine on since the machine had 80kms '03 with bender jetting specs i now have 6500kms absolutly no problems, I added a digatron this season for curitos and the the egt's are bang on 1290,1290,1250 at wot, hope the info given helps. Shane
