bender pipe bog ideas
mbviperboy
winnipeg
looking for feedback,
been having a bog in powder with my newly piped viper, works great on trail and good for a minute in powder then it bogs, it will clear itself out once i get back on trail or let it sit for a minute or two , could it be powder coming in thrugh the front vents and cooling off the pipes? would that cause it to bog? Any mountain riders with bender triples on their viper, if so are you doing anything with your vents?
Also i did not remove the shelves in the airbox based on some posts here, could that be my problem?
do the air box, mine is mountain viper no problems, talk to powervalve-700 he to had a short track doing the same, just check his treads.
It seems to be the exhaust plugging up, mountain vipes seem to be a bit better probably because they sit a bit higher or float over the snow instead of plowing through it like the shortys.
vipmtn03: what part of Labrador are you from?
you could have snow around the exhaust or getting in the airbox, however, if all you do is pull out on hardpack and the problem goes away, without touching anything else, I would think that the clutches are overshifting in the powder and lugging the engine acting like a bog.
OK here is what I had in my sled for March 11 2006
2002 VIPER 136 X 1-1/2 CPR pipes & head mod
Attac
162.5 162.5 165
2.5 2.5 2.5 3-groove washer above & below
47.5 47.5 47.5
1-3/4 1-3/4 2
primary: 8EK empty stk spring YWY
secondary: 43' silver spring 3/3=60' (moved it to 80' when I rode it )
clutching works the best it ever has 9000-9200
19/41 gears 68 link stk chain HIGHLY RECCOMEND
not good for high speed trail ridding but who the hell wants to do that. LOL
was running 21/38 it SUCKED! could not cool belt
blew 2 belts 2 trips, rode last trip on same Yamaha belt and going with it again!
stock mountain viper exhaust deflector ( WHATS WITH THE HOLE IN IT?? )
sucking only outside air, ram air & dash flo-rites
2 flo-rites in dash, ram air flo-rites
drilled 2-1/4" holes in ram duct to dump air on top of air box, taped off end going to engine compartment
air box pre-filter
taped off ALL under hood air for air box
taped off the 2 holes in frt below bumper
put smaller screens over hood screens (needed??)
STILL BOGGS IN DEEEEP POWDER OR CARVING TO THE RIGHT
