03 Mtn. Viper, new motor this season, SLP triple pipes, was out of the chassis, wrapped lower engine wiring in plastic loom after checking for chafing when the motor was out.
Chasing some intermittent blinking of the self diagnosis light.
Sometimes low speed blinks 3 or 4 times in short succession then nothing, can't see quick enough to see if the temp or service engine icons are also blinking. (to quick)
Quick fully pinned short pull same effect slow down to look at the gauge and stops blinking.
One time about 5 seconds of quick blinking and engine icon (should be PVs(?))
Rear cooler gets hot so and I haven't seen the temp blink unless thats whats going on the WFO pulls, but it quits before I can check for an the icon.
Never got a real good count on blinks cause when I slowed down to focus on that it would stop.
Also bar warmers seem to have ceased functioning.
Will idle forever with no overheat indications.
Powervalve servo motor worked fine, both by wiring (ala tool) and by bringing the idle to less than 1k. Didn't check this ride first thing on the troubleshooting list now that it is thawed in the garage.
She runs good though
Thoughts, suggestions, feelings on the matter??
Erik
Erik
