I have a 99 600 sx it is piped,ported,cluched,geared same as 700,reed spacers,thiner head gasket,stock carbs (31mms) I was wondering if anyone has tried puting 33mms on.
change_up
I can't tell you too much other than Aaen's install instructions for their triple pipes recommend 38mm carbs from 31 for an additional 6 hp... then you are ported so that might change things a little yet.
From 31's to 33's with porting I would say you would probably be up 4hp max... but that's about the wildest guess I've made yet. lol.
Just wondering... mine is an Aaen piped 99 600... i hit about 180 on the speedo on a good day...
If you don't mind me asking what are you hitting with yours, who's pipes, and porting? and how's gas mileage?
speed
I Have seen 180 on a good day as well but consistant 170-175, Bender pipes and trail porting, gas mileage is o.k.
change_up
Maybe if you took the 33's and bored them to 35.5? Hauck claims 6hp as well... either way if you bore them, get a different carb alltogether, or just put on the 33mm's you will be getting a gain by helping the engine breathe better. My opinion is do it... I've been thinking about the same thing along with porting.
http://www.hauckpowersportsinc.com/clearancedetails_1012_1.aspx
**sj**
Life Member
might have a set of 35.5 bored carbs available.. p.m. me if interested
