I have a 98' SRX and was wondering what everyone is running for gearing? Is a 20 tooth driven gear [drive gear is stock] too small?
pro116
Lifetime VIP Member
depends what you put on bottom I would think around 21-40 would be good for 660.
yes or 39 -20 1.95 ratio has worked out fine in 660 feet..
pro116
Lifetime VIP Member
20-39 work's great for 500 ft I would go 21-40 or 21-39
Thanks guys!! I still have the stock 37 on the bottom and I have a 20 on top.
I've just worked on the stock clutching till the rpms hold 8300-8400, would I be gaining anything by going to an after market helix? If so what should I go with? I use it for occasional 660ft drags but mostly for trails.
YAMMIEGOD3:16
21-40 !!! 98 mph in 660 WITH MY 00 SRX ON ICE. 3:16 (tony)
YAMMIEGOD3:16 said:21-40 !!! 98 mph in 660 WITH MY 00 SRX ON ICE. 3:16 (tony)
Nice!!!! What clutch setup are you using?
YAMMIEGOD3:16
MY HOMEMADE ONE!!! 3:16 (tony)
