Primary Weights Weight???
Exciterfan
West St. Paul, Manitoba Canada
Just a question for those clutching gurus. This site has a section where the Yamaha specs for the various Primary weights are given. An example is an 8CH is speced at 35.32 grams. While I was tuning my clutch, and adding rivets to the weights, my resulting measurements were higher than I expected. I was using a calibrated scale.
Is the reason for the differential because of the bushing? If so, is there a basic amount you'd add in for the bushing? Or do you have to weigh the weight with no rivets to start with, so you know what they weigh bushed?
Exciterfan
TY Forums Tech Page
Go to this section. You will find all the info on the OEM weights & springs under clutching.
Madmatt
