Whats the best engine cleaner for sleds?
I've used gunk engine brite before with good results. I sprayed pretty much everything, didn't have any problems, just made sure I gave everything a good rinsing and then dried the engine thoroughly. It made it a lot easier to get the built up crud off of everything and the engine looked brand new afterwards.
Just watch when you wash the engine there is a hole ontop of the recoil. I think its to set timing. Mine is covered now so no water can get in. Just word to the wise.
I like the Citris Engine Bright from Gunk. as good as the original but smells better. Just cover the electronics with a baggie and keep it off the clutches.
