700 SRX advice needed
tucker144
central ia
I have a 2000 700 SRX it has about 2200 miles on it. I have put a GYT silencer on it and also a 136 X 1.5 kit. Cant remember but I thik clutching is stock along with gearing. Was thining of putting a clutch kit on it or changing clutches totally. What are some good performace clutches? Right now it tops out at about 100 mph. It has a great hole shot and midrange seem good. Best comparison is I ride with a 2005 Firecat 700 and I Beat it every time out of the hole shot and till about 70 mph. Any advice would be greatly apreciated!
wow, that is one hell of an overrev on a stock srx. MORE WEIGHT MORE WEIGHT MORE WEIGHT in that primary!!! Also check to make sure that none of the bushings are binding in the clutches, that all sliders, pins, and rollers look good, and that the center to center and alignment are within spec.
