Well this is really testing the memory but I'm gonna say no and yes, yes because it will bolt in and look like it fits correctly, then when you go and put in the gears, they won't fit, the splines are different on the EXII, when they went to silent chain the spline shape/count changed, and its just a little, so if you get a used shaft, slide your gear on before you start installing it.
