sl 433???
Around 30 hp at 5,500 rpm in 73 literature , basic engine same for EW , EL , SW
74 shows 31 hp at 5,500 ..SL and TL (TL had diff crank) GP had 39 hp @ 7'000.
74 had bogies , rear fuel tank 15" track....What did you want to know ??
well to be perfectly honest. my cousin bought something else and the guy gave him these two. I do know that they are not for a gpx, but i didnt know if there was aa actual sled sl or if these were form an exciter or something else???
I didn't check mine , but the serial number on the engine matches the sled it was from
and the model # is likely stamped to engine for assembly line purposes. If they are SL
chassis / engines ...single carb , oil inj,gear driven , 2 into 1 exh manifold , fan cooled ,
fan fastened to flywheel , keihn carb w linkage to oil pump , simple dependable engine .
RON
thanks you, that is what my cousin thought but we were just hoping that they might be something better. thanks for all the help guys
