How to take off the rotor??
The rotor and hub is simply on a key and should slide right off. There is a collar with an o-ring in it the spaces between the rotor and the bearing.
just use a rubber mallot i had to pund on mine pretty good to get it off sometimes it seizes on there try some penetrating oil and let it sit an hour or so then pound on it. it'll come.
Auji, don't take this the wrong way, but I think getting a service manual will save you a lot of time and hassle in working on the sled.
If you have never had it apart before it may come off a little hard, but there is nothing "holding" it onto the shaft except the caliper. It is a keyed shaft.
If you mean how to take the rotor off the hub?. Then you will have to grind the rivets off one side. Then replace with new rivets or bolts & nuts.
Do they sell them that way?...ifn you need a new rotor get the actual part you need, don't try to piece er together,jmo
