SRXtrafast
I keep the fuel low in the tank and mix Marvel Mystery Oil as recommended on container and then make sure the sled runs long enough to get through fuel system. For pistons and cylinders I use 10w-30 Cen Pe Co motor oil and coat the cylinder walls[use a container w/ flexible spout making sure each piston is at top of stroke]. Put plugs in and pull it over 2-3x w/caps off and do it again. Plugs don't foul in the fall either.
Dump fuel stabalizer into whatever gas is left in the tank at the end of the season(around half this year). Run the sled for ten minutes with the oil cable fully extended, wash, grease, wd40 and store in the trailer.
TimeBomb
put her away last weekend. i just clean it, pledge on the hood and i use a plastic/rubber/vinyl protectant i got from my previous job for everything else. its used for cleaning golf cars and it works really well. then i run it for a few minutes with the oil cable out, put it up on a track stand and cover it in the shed.
Yamahammer485
crewchief47 said:Dump fuel stabalizer into whatever gas is left in the tank at the end of the season(around half this year). Run the sled for ten minutes with the oil cable fully extended, wash, grease, wd40 and store in the trailer.
Exactly what we do, there is 0 difference besides us putting our sleds in the garage instead of trailer.
PZ 1
- Mar 12, 2005
my way
Snowmobile Summer Storage
Start sled and warm it all the way up.
Drain all the gas out of the tank. I use a siphon into a 5 gal gas can. Good rule is if it has a plastic gas tank drain it dry, if it has a steel tank fill it up so it does not rust.
Start sled and run it until it stops, use the enrichener as it starts to die to keep it going.
Attach your fogger lines into the carbs. On the newer triple motors you can go in at the carb boots right into the carburetors. If you have a Phazer you can pull off the small rubber plugs that cover the brass tubs that are on the intake boots, you can then put your fogger lines over the brass tubes. If it’s a twin with the boost bottle you can remove the boost bottle and make two plugs that will fit in place of the bottle and drill a hole in each one for you fogger line.
Start spraying the fogger and start the sled. The sled will run on the fogger. Use the throttle just enough to keep the sled running. Run it until it is smoking well and let the motor slowly die as you are still spraying.
I use silicon spray all over every thing, track, bogie wheels, seat seams, hood straps (leave em unhooked), wiring, hand grips, basically all the rubber stuff.
Grease the suspension. Some people will loosen the track.
To keep the mice out put steel wool or a dryer sheet up the exhaust outlet. Put tape or a dryer sheet over the air box intake, maybe through one under the hood too.
When getting ready for that first ride of the new season, put in fresh gas and pull and pull and pull. After you have all that fogger cleaned out, install new plugs or at least clean the ones that are in there.
I don't think I can stress enough about getting all the fuel out of the system for the summer, I had worked at a dealership several years ago for several years and I cannot even begin to tell you how many carbs I have cleaned because people let the gas set in the carbs all summer. Then they wonder why the sled won’t run right. Same with bikes over the winter. The jets and passages in the small carbs are not very forgiving and the gas goes bad very quickly.
Tod
Tod
taylzee
If you just want the fuel not to cmpletely rot then use the stabilizer. Just make sure when you get it out of storage that you pull the carb float bowls and make sure the jets, pilots etc. are clean. I don't get into the fogging as I like to start mine every couple weeks and bring them up to operating temp (good and warm). My neighbours don't like it too much, but hey forget em if they can't take a joke. I think it may have something to do with the smoke cloud that linggers around for a while on a nice calm summer day.
