Stock SRX 700 jetting?
I jetted down my 01 and it made a huge difference. I know I would be careful with anything below Zero F with my jetting, but down to that the plugs look good.
Sounds like your sled has the 01 specs in it which is good, The 00's where slightly leaner. I would not stray to far from where you are at, there where alot of burn down complaints on the 00 in real cold temps.
DUDE, THOSE ARE 2001 SPEC,s, 2000 STOCK JETTING WAS 147.5-146.3-146.3!! NOT A BAD THING, 2001 JETTING WORKS REAL GOOD. 3:16 (tony)
00,s were jetted lean & had some burndowns. Run the 01 jetting. The Yammie triples like fuel & you gain nothing except an expensive rebuild bill by jetting em down.
I am going to have to go look at what I did. I know I wrote it down in my service manual. I have run it this way 2 seasons now, But I know it's jetted down from what it came stock (01)
