Hcivic88
- Feb 24, 2004
hey
I was wondering if anyone knew what size jets i would use for my 1994 yamaha v-max 500 l/c. The reason i am rejetting is because i am installing some DG pipes.
can anybody tell me what size I need to use?
thanks a lot
Jamie
thanks a lot
Jamie
94V-Max
the pipes should have had all the correct info on tunning but if they didn't then i would call DG to get it.
Hcivic88
- Feb 24, 2004
well the thing is.. i bought the sled used.. and the pipes came seperately with it.. so they didnt come with any papers or anything to tell me...
thats why im wondering if anyone else happens to have the same pipes or something..
94V-Max
Well what I think you need to do is call DG and get all the spec’s for the pipes because I think that you might have to change the spring position on the secondary clutch. But I would be careful with pipes because I know from experience that you can melt down these sleds very easy if you don’t watch it I did on mine and that is why I now have the factory pipes back on and I have my SLP pipes on a hook in the garage.
