SRXtrafast
Does anyone know the hp on the srx 600? Was there any difference between 98 and 99?
I believe it was around 114 hp.
SRX 600 was about 120 hp...maybe 124 on a good day. 98 & 99 were exactly the same. 99 had a beefier crank. I owned a 98 & 99 600 SRX.
Cuzino19
Unless it's Brians SRX600 hey turk? lol.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
I believe the 98 ran a colder plug then the 99. The 98 ran a BR10ECS where as the 99 ran a BR9.
The 9ecs was a later change up on the 98,s. That was the year they were fouling a lot of plugs when initial starting the sled in cold temps. It was 90% to do with procedure but changing to the slightly hotter 9ecs plug helped.
SRXtrafast
SRXtrafast
If I shave the heads will that stress the crank too much?[98]
most likley no! i had a 99 600 and ran it with empty airbox and stingers, now i have 700 cyl on the same crank.. no problems there..
98srx6
SRXtrafast said:If I shave the heads will that stress the crank too much?[98]
If it does "stress the crank too much" dont worry, I happen to have a good 600 srx motor for cheap.
aSRX600guy
how cheap? pm me, I may be buying somtime this summer
