oil change
Air box comes out first. Oil filter is under the battery tray, you do not have to pull the tray out, just un-bolt it. 5mm allen bolts hod the acess cover to the bottom of the sled, with a 6mm bolt for the case drain. If you have a skid plate it needs to come off first. The oil tank is in front of the chaincase/brake, so the right side cover needs to be removed. 12mm bolt (if I remember correct) is the drain plug. Also, remove the tubr next to the tank drain (5mm allen bolts) and clean the screen that is attached. I always added 3qts of oil on the fill-up and never worried on the oil galley bolt as there will be a warning light the will pop up on the dash if you are not getting oil to flow...
