SX verus SRX rear heat exchanger
1badz
Can someone tell me the difference in an Sx and an SRX rear heat exchanger?? Skidooboy said that an SRX rear exchanger is the same as a Viper ( not sure if he meant Viper or Mtn Viper ) What's the difference in an SX rear exchanger?? Is that similar or the same as a Mountain Max rear exchanger?? Thanks Want to use it in a 2000 and newer MM tunnel extension on a 136" Viper conversion.
Sx/mm rear exchanger is about 1/3 the size of a srx/viper exchanger. This also means there will be more room needed to accomodate a srx/viper cooler than a sx cooler.
Forgot to add. Depending on how long the rear of the extension is (where the flap mounts) will also determine what cooler you can use. MPI uses a modified sx/mm cooler as a srx/viper cooler is too tall to fit inside the rear of their extension. This is also the reason why u-coolers were made...
