SRXtrafast
i just had the heads norelcoed .010, what can i expect for hp gain? or will i just receive crisper throttle response?
most of the power you will find in the Mid Range and it will really clean up the low end burbble.
A Kennedy
Was the heads cut .01" from just the gaket surface? Or did u also have the squish band cut deeper as well?
SRXtrafast
srx head shave
I believe it was just the gasket surface which was cut.
