Canuck
My son is considering purchasing a 97 SX700, he's always liked this model. I have a couple of questions.
Were there any issues with this sled, just wondering being that it was the first year for this chassis and engine?
If we wanted to add the newer style trailing arms for the OEM plastic skis, is it a direct bolt on or do you need to replace other parts?
To do a Viper shock upgrade, will the top mounts fit the front bulkhead?
Thanks,
Ken
Thanks,
Ken
sx700
One of the best sleds made I have 2 of them 97 & 98 if you want call me I can give all the info you want Jerry 807-274-6907 sorry but would take long time to type the info easyer to talk
xt700
- Jan 27, 2006
you dont have to change the trailing arms to put plastic skis on. if you have the plastic skis and sadles thell bolt right up. Pat
Chasx7
I put a set of 98 SRX skis on mine. Bolted right on. Put a set of shims in it to keep the darting down. See if you can find a roller clutch for it. I put a Maxximum on mine and it works real well. Great sled.
Canuck
Thanks for the replys!!
Jerry - If we end up getting the sled I will probably give you a call.
jwiedmayer
97's had weak mag side crank bearings. They can be updated when it goes.
Canuck
Is it common for the bearings to fail, is there a particular mileage that they tend to fail at? Is any machining involved to install the updated bearing?
Thanks!!
Thanks!!
jwiedmayer
Its pretty common. The 97 had twin ball bearings on the mag side. 98 and on all the tripples used a big roller bearing. To update it you just need to add a pin to the crank case and intall the new bearing.
There was a couple of recalls on the 97's. They did a silent recall on the trailing arm mounts at the tunnel, the stock rivets where small, they are essentially just replaced with larger headed steel rivets if I remember correctly.
Also taller bumpstops where a available for the rear skid W arm.
One easy thing to check on a used sled is to get the VIN number and call Yamaha Cust Serv. They will give you a dealer history if any dealer repairs or warrenty work has been completed as long as the dealer ran it through Yamaha anyway. They will be able to tell you if the Dealer updates where done as well.
Overall that motor was almost bulletproof
yamaholic22
Great sleds, do the updates these guys said (dont do the crank bearings until when and if they fail). These sleds really are bulletproof when maintained.
snowfoxsx
my crank bearings went out at 15000km's!!
like they say recals only mean as much as half of the cases. Look like you got a good deal!!
vmadmax
I did the bearing replacement just this past winter. It went very well. Sled is awesome! Sled had 3,000 mile, however it did sit for a season, allowing that bearing to get nice and dry.
Blue Hornet
I had a 97 700 and absolutely loved it. The only problems I had were the crank bearing problem and a bad stator which Yamaha covered. I added USI Tunnelblades and had 144 pics and have not yet ridden a better handling sled. A really good recomendation would be to add The wider handlebars from SX-R's. It makes a huge difference. The motor is a honey.
