Anybody ever used stor tech plugs. If so worth it, or better off fogging?
Hmmm...never heard of the plug.
aSRX600guy
I think they are just plastic plugs with a desicant inside. wont do much for the crank
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
Ya they're just plugs some stuff in there to soak up any condensation. Like SRX600guy said though, won't do much for the crank. You'd be better off fogging the sled.
OK...now i remember what they are...yea i would'nt use them put the fogg
to her that's better..............
ok. I figured it sounded to good, lol! I still can't summerize yet though. I gotta get a roof on my new garage where the sled is going. It's about 100 feet from where the sled is now! Can you say grass drag!!
800
start em up once a month, don't worry about fogging them, there more than enough residual oil in the motor, heat gets rid of the condensation.
shortstop20
- Mar 6, 2005
That works too. In the past I've just started up my sled once every month or so also. I think I'm going to try the fogging method this year.
I won't fog it. I will take her out at least once a month. I asked about the spor tec plugs cause I thought it may help in between start ups.
maxout01 said:I will take her out at least once a month.
to do what???
quick ride!! very quick!
^^^ LOLmaxout01 said:quick ride!! very quick!
03viperguy
I always drain the gas and run it till it dies. floods out once it runs out of gas. no gas to go bad and cause issues either. always worried that the starting it up method would leave more condensation from going hot-cold-hot-cold
The temp all winter where I live has been bouncing from 20-50+. I have to be able to run it to move it.
Fogging
A question about fogging.. How much of the fogging oil do you use per sled?? Also is the pennzoil marine fogging oil the same thing as the sta-bil brand??
maxout01 said:A question about fogging.. How much of the fogging oil do you use per sled?? Also is the pennzoil marine fogging oil the same thing as the sta-bil brand??
I use yammie brand, they say to spray one minute in each cyl. back and forth i got a twin so i just use two cans and spray in each cyl, for a minute.
Spray wile running of course......
so I would use one FULL can per side??
One can should do a triple.
ok cause I have to do two sleds and wasn't sure how much to buy.
maxout01 said:ok cause I have to do two sleds and wasn't sure how much to buy.
Your motor will love you!!......LOL
