didn't drain the coolant in the off season
Fasterblaster
Vancouver, B.C.
next issue... i didn't do it... i was going to and somehow its already Sept... If you didn't drain your coolant in the offseason, what would you do now as the next best thing?
97 600 MM :oops:
then you would want to remove the old gas and drain and clean the carbs then...make sure its not all varnish and .....clean the main jet and pilot area....
