need an ohlins shock
Fast Eddie
Livonia
My buddy crashed my 98 srx700 and wiped out my right front suspension. I was wondering if anyone out there had any control rods or a ohlins shock.
thanks
That was me .I have one off a 97 sx .I am not sure if it is the same as a srx.Maybe someone can tell us if it is?
I have one off an 1999 srx but the yellow paint on the spring has some chips and you can see rust on the spring. It has about 6000kms or 3600miles. I also have 1 or 2 control rods also a control arm. let me know i can post a pic ;)!
shocks
I think an SX will fit an SRX but is valved different. The SX I believe has a black knob to adjust the compression and the SRX has a slotted clicker adjustment control
sx and srx arent interchangeable. the bulkheads are different. The srx has a 3 bolt mount and the sx mounts with 1.
the sx ohlins will work on a srx and vice versa. the shock mounts are not changeable. Maxdlx
max is right, however, you shouldn't mix and match the ohlins from an sx and srx, make sure they are both either off an srx or both off an sx, because the valving and spring rates are different, and handling will be affected.
