whats it take to make this work, i bought a srx 700 with a bad centre rod bearing and have this bramd new viper crank sitting around,seems like a waist to putr it in a 98 srx700 but it is here.all i can see is the outer bearings on the pto is changed from 2 to one bearing,
800
you got it, but you're not gonna put that in there, how much? I hear it was getting priced in my range. Send em both down I'll fix that 98 crank, you can put it back in.
i see used ones going for 300-400 , this thing should be worth what?? 600.00 what would you sell one for bill, i found a donor crank for the srx with a bad rod also, should be able to make somethin work, really seems like a waste to putr that new crank in a old sled
