montynormand
Here's one for you guys..... building a enticer 440 piston port single carb motor for next race season. slight porting, nothing too wild. raised exhaust and cut piston skirt only.
what size carb should I look at? I was thinking a 38mm flat slide or a 40mm round
RJH
What ever one you have more jets for.
If it's a TMX or TMXx flat slide - then you are stuck with the tube it comes with. The round slide - you can fool with the jet needle tubes.
A TM is adjustable like the round.
