Track???
I plan on putting one similar to that on my new sled (phazer). 121 x 14 x 1.375 polaris track from a pro x.
Yes
Hey Magic, that's the track I had on my 780 when I came up to Otis. Only thing is that the fingers in the middle are 1 1/4 and the outside is 1 1/2. I cut the outside down to 1 1/4 so they were all the same and to save on drag. It's an excellent track but in comparison to the Ripsaw and the 9818 which are also very good the 9900 is EXPENSIVE. I think it's a supply and demand thing.
Madmatt
Thanks Matt, And It Did Not Look Like It Lost A Lot Of Topend.
I Think I Will Give It A Try. ;)!
I have one that might be for sale. it is 136, and is the 14 wide version off of a ski doo. The lugs where cut for ekchanger clearence, and some of the lugs tore where they cut to wide. i'd take 125 plus shipping for it. Maxdlx
SRXMAGIC said:
Anyone Try A Camoplast 9900r Snowcross Track??
Magic,
I've used the 9901 (136" version) on my Viper. Madmatt is right about the staggered lug height between the inside (lower) and outside (higher) lugs. I've used it as a trail track and left the higher lugs the stock height without cutting them down since I'm old and don't care so much about the drag. I think it's an awesome all around track, especially if you like what a 136" can do. I think it hooks up a lot better than a 1.25" Ripsaw, and if you're not going to use studs it's hard to find a better all around track.
Boomer
