Will a Viper reverse kit (Part # 8EK4759000) fit on an SRX?
Thanks for the help in advance. 9er
If it's the 00-02' Srx yes. They will have the same gear type. The kit may have a different bottom gear than yours. You'll use your srx top gear with the kit. It's a tight fit but it's well worth it. There's a detailed install in the technical pages. Also do a search on it, it's been touched on a few times.
Rich
Rich
aSRX600guy
I heard the oem muffler wont fit
It will fit. The shelf on the chain case cover will need to be removed (as stated in the tech pages). Believe me, I've done it.aSRX600guy said:I heard the oem muffler wont fit
Zack1978
- Dec 12, 2005
wanasrx said:It will fit. The shelf on the chain case cover will need to be removed (as stated in the tech pages). Believe me, I've done it.
How much would you charge to do it on my 00 SRX?
Zack
So do you need a different top gear and/or new chain to maintain the correct ratio, if the bottom gear is different?
Sorry for the late reply. The pc went down. It's really not that hard. If ya was near by I'd give ya a hand.Zack1978 said:How much would you charge to do it on my 00 SRX?
Zack
SRXer said:So do you need a different top gear and/or new chain to maintain the correct ratio, if the bottom gear is different?
Yes, that may be necessary. My 01' came with 23/38. The kit I used came with a 39t which worked with my 70 link chain. I never noticed any top end loss. The kit you listed should come with a 38t which would be the same as the original. Just through it in.
