friend has an 01 srx and wants to run vforce 3's, anyone do this and what is the feedback?
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
Not much to be gained on a stock or mostly stock sled other than a little throttle response from what I'm told.
sxviper32
yep, shortstop's correct. throttle response is a bit crispier on a stocker, you don't see any gains really till you start boring, porting, etc.
vipertripplexxx
3's work good on a big bore.
Brad_69
I waisted my $375. On a set of V-force 2 reeds. I lost throttle response, and the sled ran a little fat. Plug color was even a darker brown. when I reinstalled the stock reeds everything came back (stock jetting). Brad
yamaholic22
It says right in the instructions that you may have to jet down from stock because the aftermarket reeds have a tendency to richen the calibration.
