killerklown
Can I get an accurate compression reading with no intake, reeds, or carb on the engine?
Brad_69
I would say you can. Normally you are suppose to hold a throttle wide open and pull it over at least 5 times. I strong running 535cc fan should run around 150 psi. Brad
