Best Stud for Grass??
What kind of track are you going to run? The Megabite studs have a very square tip to them and bite pretty hard. If you're going to run a speed track you can't go wrong with Woody's 1.060 chisel studs!!
I have just a one inch track, not sure if its a stock replacment or not but its in pretty good shape. I was thinking about the chiesel tooths but want something that I can use in the winter also. It has 192 worn out chiesel tooths and thye aren't worth anything once they are worn alittle. Also I run it on the lake after grass drag season..but I may just go with the chiesel tooths.
