What sort of tools are needed to do this? I'm not sure if this is something I should tackle in my garage are not.
How bad of a job is it, pull the head, then each cylinder, replace the gasket, then use a piston ring compressor to the get the pistons back in?
If I decide to do new rings while I'm in there do you guys hones the cylinders or not?
Thanks!
Thanks!
