nosguy
I have a set of 40-10Y Heel clicker weights. Fully loaded they weigh 64 grams (4 gram bolts tip and middle, (3) 1 gram washers on each bolt along with (6) .5 gram washers on the heel with 1.2 gram set screw.) I NEED MORE WEIGHT!!!! How can I get these thing to weigh near 90 grams???
I called Fett Bros for some tungsten washers but I would have to notch the tip of the weight to make them work because they are slightly larger than the washers that come with the Heel clicker kit. And I would only be alowed to run the tungsten washers on the tip because putting 2 tungsten washers side by side (tip and middle) would interfer.
Even with tungsten washers in the tip and stock washers in the middle, I still won't achieve near 90 grams.
Any suggestions?? Prefer not to buy another set of weights! I just got these...
the easiest solution would be to use a softer spring, this makes the weights act " heavier"
