1988 Exciter Carbs
Tomahawk
Hi,
I'm rebuilding the carbs on a '88 Exciter. The sled has a DG pipe, what size should be the main jets? Also, what are the electric switches for that are on the carbs? Any help would be great!
Tim
The switches are for the TORS (throttle over-ride system). Info on that in most of the yamaha manuals from the mid 80's on. Maybe even in the tech. pages here? Not sure about the jets, you could contact DG for that, take into account your elevation, and any other mods(air filters, porting, etc...). Even then keep an eye on your plugs.
Thanks killerklown, I was able to find info on the tech pages, and I searched the forums using TORS. It helped alot!
