2002 viper
- Aug 7, 2006
I am looking in to buy the 835 kit from bender,new rear suspension,front shocks and a new 1.25 inch track and skis. Can you guys give me some info on the kit and what rear suspension i should look into? I also would like to know how would the 835 viper be vs a Zr 800 with a 870 kit in it from D@D.
1 bad bolt
- Jul 23, 2006
im curious to know the answer to your questions
aSRX600guy
no 1st hand experience, but Ive heard the 780 kits were better than benders 835.
03viperguy
what kind of riding do you do? I am a trail rider and the monoshock I bought is a perfect fit for me. give us a rundown of the types of trails etc you ride for the suspension ideas
2002 viper
- Aug 7, 2006
03viperguy said:what kind of riding do you do? I am a trail rider and the monoshock I bought is a perfect fit for me. give us a rundown of the types of trails etc you ride for the suspension ideas[/QUOTE
I ride mosly rough trails....any info about the 835 viper?
bufalobob
i have a bender 835 in a srx & 800 in a sx. i put sxr wide front end on both & viper update shocks front & rear. motors are bullet proof. lots of miles & no problems. the mistake almost everyone makes when modifying a motor & increasing hp is neglecting the cooling system. increased hp means more heat. i added bender's tunnel heat exchangers to both sleds. we ride ontario lakes a lot & never have a problem. we have all makes & models of sleds when we ride & switch back & forth. as far as suspensions go they all have their good & bad points but both ride just as good if not better than the new stuff.
i have radared both sleds in north bay @ NBSSR & the sx does 115 - 122 mph & the srx 118 - 125 mph ( depends on the conditions of the day ) in 2000'. that's with trail fat jetting, 1" camo predator, 240 megabites & trail ride heights.
what sleds will you beat in trail form accross the lake? almost all. this a real 185 hp motor on pump gas.
bob
bob
2002 viper
- Aug 7, 2006
Thank you, How much you pay for the kit?bufalobob said:i have a bender 835 in a srx & 800 in a sx. i put sxr wide front end on both & viper update shocks front & rear. motors are bullet proof. lots of miles & no problems. the mistake almost everyone makes when modifying a motor & increasing hp is neglecting the cooling system. increased hp means more heat. i added bender's tunnel heat exchangers to both sleds. we ride ontario lakes a lot & never have a problem. we have all makes & models of sleds when we ride & switch back & forth. as far as suspensions go they all have their good & bad points but both ride just as good if not better than the new stuff.
bob
SpartaSXr
If you are looking to beat the cat I wouldnt put an 1.25" track on it. you will lose a little speed
bufalobob
02 viper:
price depends on what you want. you will need triple pipes, bored & ported cylinders, pistons, tunnel heat exchangers, vforce 2 reeds & clutch parts for a basic setup. this will give you around 175-178 hp. add case porting & 38mm rack carbs & the price goes up but so does the hp - 185 to 190+ depending on compression & porting. call mike @ bender for prices - 1 585 937 6829.
bob
bob
