SRX thermostat
SNOWRULES
Ottawa. Ontario, Canada
Is there a thermostat in the srx cooling system? If so where is it? I'm going to try grass dragging and i'm gonna build a cooldown cart but need to know if there's a thermostat i need to remove to let my system flow freely.
I would not remove it, the coolant will flow to fast. This could cause a condition where you might over heat the cylinder head and cylinders. Instead block the stat open, this will allow free flow and you will still have a little restriction in the system. I also built a cool down cart, if you need help ask me..
