clutch spring
EricMichael
Presque Isle, ME
I have a black secondary spring and a black primary spring with white yellow white on it..anyone know if this is any good for 500 ft??The helix is a 51/45 wound at 70 degrees.any help would be apprieciated!
is there no colour mark on the secondery spring? the white-yellow-white is a good spring, maybe a little strong depending on your weight and so on.. i like the blue-white-blue! but much people use the white-white-white!!
I weigh 145 , i also noticed it had two shims in it, not sure if i need them or not?and the secondary spring has no markings that i could see..
