maha
It's in a Venture, not that it should matter, but it's bone stock. I put a 151"x1.25" track and set of rails on it and would like to get a few more horses. Any ideas? Thanks
			Aaen
aaen exhaust.if you can find a cold air intake yet those work great on them.
Skidor
maha said:It's in a Venture, not that it should matter, but it's bone stock. I put a 151"x1.25" track and set of rails on it and would like to get a few more horses. Any ideas? Thanks
Get as much extra weight off of it as possible. With the 151 I assume you are doing some offtrail. Take off anything extra you don't need. Speedo, Fuel guage, oil injection (premix it), windshield, cut the seat down, replace the seat bottom plywood with a lexan sheet (it won't absorb water weight), mirrors, hotdogger, etc.
PZ 1
 - Mar 12, 2005
Take off the side panels.
...Intake gets cold air and everything- clutches, belt, brakes, engine, etc.- runs cooler.
Aaen pipe ,  performance reeds, and a cold air intake will really make a difference...I believe it goes from 57 hp stock to almost 70 hp with these parts ..........
